Giriş
This guide will walk you through from taking apart the device, disconnecting all the cables inside and taking apart the battery for replacement.
There are two versions of the battery in this device; one with three wires and one with five wires. The best way to tell which type of battery you need is to disassemble your device before ordering a replacement battery.
Neye ihtiyacın var
Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
Gently slide the NFC chip into the device through the slot that the wire comes from.
what if the wire DID disconnect? could s.o. add a detail pic of exactly where the cables connect on the chip?
Need the real name of the NFC chip, caus i broked and need to change
Thanks
Need the real name of the NFC chip, cause i broked and need to change
Thanks
My chip reads
WN-3088 20130912
Remove the two 7.0 mm Phillips #1 screws.
Carefully detach the silver plastic cover by pulling both ends off.
Separate the silver plastic piece by pulling it off from the middle.
Tutto molto interessante.
Ma la cosa più importante è:
Dove acquistare gli altoparlanti ??
Using the classic spudger, get underneath the black tape strips found on both side of the device.
After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
Keeping the tape intact is impossible - I replaced it with electrical tape.
Use the black spudger to disconnect the auxiliary wire from its socket.
What is the function of auxi. Wire
When you plug in the audio jack it goes to the motherboard, the amplifier and then to the wire directly to the speakers.
Carefully remove the cable connecting the control chip to the motherboard.
What's the name of the cable connecting the control chip to the motherboard
I want motherboard control chip
connecting the control chip kitne ka hai
Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
Remove the one 7.0 mm Phillips #1 screw attaching the motherboard to the casing.
Lift the motherboard out of the case to reveal the battery.
Using the black spudger, loosen the battery and remove.
Hi!
That looks like two stacked batteries, to give +/- 3.7V with a ground center?
Having the dimensions of the pack would be great, making it easy to find suitable replacements!
Thanks
Patrik
18 farklı kişi bu kılavuzu tamamladı.
10 Yorum
were i can buy a new battrery?
I just managed to find a replacement battery for the older JBL Flip2 , which has a LI-ion battery (just three cables with a different connector) for in this feature just the newer Lipo battery is covered:
This is the right battery for the early version:
https://www.amazon.de/gp/aw/d/B002XCR3UI...
it has a different connector , so soldering the old connector to the new battery is required: Easy enough, since the colors are the same - yellow to yellow , black-black and red-red.
it‘s a tiny bit wider so with a knife the side holders have to be cut out a little, you will see when you receive the battery.
open it up first and you will see which version you have, the LIPo version has the connector at the front as pictured above, the LI-ion version has a 3pin connector at the backside of the PCB.
fir this version you need a LI-ion battery as in the link above.
Everything else is just as described above - ists such a great little speaker and Im happy that it plays again… ;-)
Hi Klaus,
What are the first letters of your JBL Flip 2 serial number ?
I don’t want to buy the wrong one, mine begins with GG letters.
thank you,
The serial number of my Flip 2 also starts with GG, which version is this?
Hey! How are you?
I want to know why this battery has 2 black cables, 2 red cables and 1 white, because i wanted to put another kind of battery that only has 1 black cable and 1 red cable
Hey,
where can I buy the battery with 1 red, 1 yellow and 1 black cable?
The suggestion from Klaus isn’t compatible.
thx for suggestions
From where i can buy these speakers?
Nitin Z - Yanıt
First thing I did was rip the wire from the NFC chip! Luclily I don't need it as I only ever use my flip with my iPhone.
Ken McMahon - Yanıt
