Giriş
Within this guide, the user will learn how to remove the speakers and check if speakers are functioning properly as well as how to replace them.
Neye ihtiyacın var
Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
Gently slide the NFC chip into the device through the slot that the wire comes from.
what if the wire DID disconnect? could s.o. add a detail pic of exactly where the cables connect on the chip?
Need the real name of the NFC chip, caus i broked and need to change
Thanks
Need the real name of the NFC chip, cause i broked and need to change
Thanks
My chip reads
WN-3088 20130912
Remove the two 7.0 mm Phillips #1 screws.
Carefully detach the silver plastic cover by pulling both ends off.
Separate the silver plastic piece by pulling it off from the middle.
Tutto molto interessante.
Ma la cosa più importante è:
Dove acquistare gli altoparlanti ??
Using the classic spudger, get underneath the black tape strips found on both side of the device.
After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
Keeping the tape intact is impossible - I replaced it with electrical tape.
Use the black spudger to disconnect the auxiliary wire from its socket.
What is the function of auxi. Wire
When you plug in the audio jack it goes to the motherboard, the amplifier and then to the wire directly to the speakers.
Carefully remove the cable connecting the control chip to the motherboard.
What's the name of the cable connecting the control chip to the motherboard
I want motherboard control chip
connecting the control chip kitne ka hai
Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
Remove the connections from the speakers.
Replace the old speakers by soldering the four wires onto each connector of the new speakers.
https://www.highlight-led.de/en/mini-bas...
This should work. Even the bracket seems to be right.
On my JBL FLip 2 speaker’s label says:
F40N8C
HS0009-0001061
8 Ohm
PS2-150HB
As I got it is 40mm (1,5 inch) diameter.
This label is quite similar to this brand: GHXamp
On my side, I ordered the speaker PUI Audio ASX04008-R from Digikey (668-1563-ND), which is the right diameter. It is rated 3W with max 5W. The down side of this speaker is the missing center cone. Hoverver, I have been able to retreive the cone from the defective speaker and transfer it. The new speaker has an adhesive ring that allow to do this. Since the new speaker doesn't have the flanges, I have cut, with a cutter, the ones from the old speaker and be able to hold the new speaker in place. To make all my test, I have used the iPhone app "Tone Generator" made by TMSOFT which allow me to select any frequency and use the balance control to compare between the right and left speaker.
The end result is very good.
Amazon Mitteilung:
6,49 $ (3,25 $ / Stück)
Dieser Artikel kann nicht an den von dir ausgewählten Zustellungsort versendet werden. Bitte wähle einen anderen Zustellungsort aus.
In Deutschland nicht erhältlich. -
28 farklı kişi bu kılavuzu tamamladı.
18 Yorum
Since I wasn’t in the US and shipping cost from the Dayton speakers were prohibitvely, I ended up finding the speakers form China. The upside is that they are easier to install, since you dont have to cut down the lateral support, the downside is that they are 6 Ohms and have a lower quality. Though I worked for me.
Hey, maybe you have the link? :)
What is the size and ohmz and watts of the speaker?
8ohms 40 watts and 1 inch I think. I been searching where to buy these as well. The rings are separated on mine
En donde puedo comprar las speaker
Instructions are very helpful and I thank you . However I now am finding it impossible to find the replacement speakers for the flip 2 so it appears the de-construction was a waste of time! Such a shame as the unit is working fine but for a buzzy speaker.
Can anyone provide a link to buy speakers please
Doe anyone know if there are any alternative for the speakers? Or the ref code for them?
I need to replace my speaker from my jbl flip ..how can I buy them
I just added a video with details on a good replacement speaker option that I used with great success. The Flip 2 sounds like new. Here’s a link to the speakers that I purchased:
I want to buy replacement speakers. Can someone share ebay.in
Its not available for indian locations.
If someone can help me to find the replacement battery? Thanks
From where i can buy these speakers?
Nitin Z - Yanıt
First thing I did was rip the wire from the NFC chip! Luclily I don't need it as I only ever use my flip with my iPhone.
Ken McMahon - Yanıt
