Neye ihtiyacın var
Remove plastic outer housing using hands or a standard spudger.
Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
Remove silicone button covers by peeling back the silicone covering. This will expose the circuit board. Disconnect the ribbon cable. Carefully pry out the circuit board and set aside. Use a heat gun to remove all adhesive so that the ribbon cable can freely slide out of the slot in a later step.
Gently heat adhesive located at tip of powerchip to melt the plastic fastening the battery to the housing. Be careful not to melt the plastic housing during heating.
Heat gun safety: http://www.powertoolinstitute.com/pti_pd...
46 farklı kişi bu kılavuzu tamamladı.
30 Yorum
where can I get replacement battery for Flip 3?
You can get a replacement battery for the JBL flip 3 on AliExpress
It is couple diffrent version of JBL Flip 3 speaker .
Yes, apparently the Flip 3 Stealth Edition looks slightly different. The procedure however is about the same, except screws are not covered by silicone covering.
my battery also went to !&&*!! anyone manage to get a replacement?? couldn't find one!
