Ana içeriğe geç
JBL Flip 3 Power Circuit Board Replacement
Neye ihtiyacın var
  1. JBL Flip 3 Power Circuit Board Replacement, Power Circuit Board: adım 1, 1 resimden 1.
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 Power Circuit Board Replacement: adım 2, 1 resimden 1.
    • Carefully remove outer housing to expose the inner components of the speaker.
  3. JBL Flip 3 Power Circuit Board Replacement: adım 3, 1 resimden 1.
    • Remove the silicone button cover to expose the power chip.
  4. JBL Flip 3 Power Circuit Board Replacement: adım 4, 1 resimden 1.
    • Heat the adhesive at the far end of the chip where the ribbon goes down into the device. Using the spudger, gently pry the chip off the board. Be careful not to melt the plastic edging during heating.
    • Heat gun safety: http://www.powertoolinstitute.com/pti_pd...
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
James Bianco
151 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Leahy Spring 2017 USF Tampa, Team S1-G2, Leahy Spring 2017 üyesi
USFT-LEAHY-S17S1G2
5 Üyeler
19 adet Kılavuz yazıldı
5Kılavuz Yorumları
If your gentle, you don’t need a heat gun. I carefully removed it with a screwdriver. Just don’t stress the board else your in a new set of problems.
Tyler Freeman - Yanıt
How do you remove the board? It says to remove the chip from the board but there are no images that show that.
Brian Barlow - Yanıt
The title says replacement, and you show only the removal.
Stanimir Nikolov - Yanıt
what could be a problem with my jbl flip 3.it wouldn't turn on when its not plugged in to the charger.
Miss D - Yanıt
Change the battery
odii Emmanuel -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 75
Her zaman: 32,342
