Ana içeriğe geç
JBL Flip 4 Controls Board Replacement
Neye ihtiyacın var
  1. JBL Flip 4 Controls Board Replacement, Controls Board: adım 1, 3 resimden 1. JBL Flip 4 Controls Board Replacement, Controls Board: adım 1, 3 resimden 2. JBL Flip 4 Controls Board Replacement, Controls Board: adım 1, 3 resimden 3.
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Pull off the cover off with your thumbs.
  2. JBL Flip 4 Controls Board Replacement: adım 2, 3 resimden 1. JBL Flip 4 Controls Board Replacement: adım 2, 3 resimden 2. JBL Flip 4 Controls Board Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool under the clear rubber cover over the button control board.
    • Pry up the cover using the opening tool.
    • The cover is glued on so it will take some force to pry up.
  3. JBL Flip 4 Controls Board Replacement: adım 3, 2 resimden 1. JBL Flip 4 Controls Board Replacement: adım 3, 2 resimden 2.
    • Pry up the button control board by inserting the metal spudger underneath both sides of the board.
    • Try not to damage the green control board while using the metal tools.
    • The control board is glued down as well, so you will need to use some force.
  4. JBL Flip 4 Controls Board Replacement: adım 4, 1 resimden 1.
    • Once the board is partially unattached, pull it off using your hands.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Philip Pang
1.252 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G3, White Fall 2018 Cal Poly, Team S4-G3, White Fall 2018 üyesi
CPSU-WHITE-F18S4G3
4 Üyeler
36 adet Kılavuz yazıldı
7 Yorum
Where can i buy ,control board for jbl flip 4?
Mihajlo - Yanıt
I would also be interested in buying a board (but the one at the top of the speaker, whichis holding the On and Off, as well as the JBL Connect button ). Thanks!
JPA - Yanıt
Does anyone at ifixit know where to get replacement boards?
EAN - 2/28/19
Eric - Yanıt
Id be interested in JBLmaking a minimally acceptable product
Mary Lea McTurnan - Yanıt
Where can I buy the ribbon cable?
Randl Manigsaca - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 99
Son 30 gün: 340
Her zaman: 31,635
