Ana içeriğe geç
JBL Flip 4 Front Active Speaker Replacement
Neye ihtiyacın var
  1. JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: adım 1, 3 resimden 1. JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: adım 1, 3 resimden 2. JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: adım 1, 3 resimden 3.
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, it will make a snapping sound.
    • Pull off the cover with your thumbs.
  2. JBL Flip 4 Front Active Speaker Replacement: adım 2, 1 resimden 1.
    • Remove all four 10 mm JIS #1 screws around the damaged front active speaker.
    • The speakers are strong magnets. Keep metal tools or other magnetic objects away from the driver.
  3. JBL Flip 4 Front Active Speaker Replacement: adım 3, 3 resimden 1. JBL Flip 4 Front Active Speaker Replacement: adım 3, 3 resimden 2. JBL Flip 4 Front Active Speaker Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool under the unscrewed front active speaker.
    • Pry off the front active speaker with the opening tool.
    • Do not yank the front active speaker out. It is connected to wires within the device.
  4. JBL Flip 4 Front Active Speaker Replacement: adım 4, 1 resimden 1.
    • Cut the red, white, and black wires connected to the speaker using wire cutters.
    • You will need to re-solder these wires when installing the new speaker.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Ryan Whitlock
2.078 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G3, White Fall 2018 Cal Poly, Team S4-G3, White Fall 2018 üyesi
CPSU-WHITE-F18S4G3
4 Üyeler
36 adet Kılavuz yazıldı
16 Yorum
And where can you find the replacement part? I cannot find a replacement speaker on the internet…
Sven Meirsman - Yanıt
Exactly, what is the part number for the internal speaker?
Dan The Menace Brenes - Yanıt
The part number is: psp00018001
Johankat -
If the magnet comes loose from the speaker how do you get it back on?
Andrew Sumahit - Yanıt
Replace the entire speaker.
Magnet realignment is crucial for the speaker to perform properly.
Johankat -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 75
Son 30 gün: 387
Her zaman: 34,322
