Ana içeriğe geç
JBL Flip 4 Shell Replacement
Neye ihtiyacın var
  1. JBL Flip 4 Shell Replacement, Shell: adım 1, 3 resimden 1. JBL Flip 4 Shell Replacement, Shell: adım 1, 3 resimden 2. JBL Flip 4 Shell Replacement, Shell: adım 1, 3 resimden 3.
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Watch out not to damage the clips on the buttons' side, pry open with caution.
    • Pull the cover off with your thumbs.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Flip 4 Shell Replacement: adım 2, 3 resimden 1. JBL Flip 4 Shell Replacement: adım 2, 3 resimden 2. JBL Flip 4 Shell Replacement: adım 2, 3 resimden 3.
    • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
    • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
    • Pry away one end of the rubber spine with your thumbs and it should come off.
    • Prying off the spine may take some persuading.
    • The speakers are strong magnets. Keep it away from other sensitive electronics.
    FixBot'a Sor
    Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Philip Pang
1.458 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G3, White Fall 2018 Cal Poly, Team S4-G3, White Fall 2018 üyesi
CPSU-WHITE-F18S4G3
4 Üyeler
37 adet Kılavuz yazıldı
3Kılavuz Yorumları
教程不难, 难的是哪里可以买到配件。
Toki - Yanıt Paylaş
Buenas tarde busco remplazo de carcasa frontal del jbl flit 4
william marin lopez - Yanıt Paylaş
@williammar67632 si encontro la pieza disculpe
Gerardo Parra - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 41
Son 30 gün: 251
Her zaman: 18,533
