Ana içeriğe geç
JBL Flip 4 USB Port Replacement
Neye ihtiyacın var
  1. JBL Flip 4 USB Port Replacement, Shell: adım 1, 3 resimden 1. JBL Flip 4 USB Port Replacement, Shell: adım 1, 3 resimden 2. JBL Flip 4 USB Port Replacement, Shell: adım 1, 3 resimden 3.
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Watch out not to damage the clips on the buttons' side, pry open with caution.
    • Pull the cover off with your thumbs.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Flip 4 USB Port Replacement: adım 2, 3 resimden 1. JBL Flip 4 USB Port Replacement: adım 2, 3 resimden 2. JBL Flip 4 USB Port Replacement: adım 2, 3 resimden 3.
    • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
    • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
    • Pry away one end of the rubber spine with your thumbs and it should come off.
    • Prying off the spine may take some persuading.
    • The speakers are strong magnets. Keep it away from other sensitive electronics.
    FixBot'a Sor
    Yorum Ekle
  3. JBL Flip 4 USB Port Replacement, USB Port: adım 3, 2 resimden 1. JBL Flip 4 USB Port Replacement, USB Port: adım 3, 2 resimden 2.
    • Remove the four 9mm Phillips #1 screws holding the gray USB port.
    • Loosen the USB cover's gray casing using your hands.
    FixBot'a Sor
    Yorum Ekle
  4. JBL Flip 4 USB Port Replacement: adım 4, 2 resimden 1. JBL Flip 4 USB Port Replacement: adım 4, 2 resimden 2.
    • Twist or remove screws from the cap. (depends on your model-version: only older versions have 9mm Phillips #1 screws)
    FixBot'a Sor
    Yorum Ekle
  5. JBL Flip 4 USB Port Replacement: adım 5, 2 resimden 1. JBL Flip 4 USB Port Replacement: adım 5, 2 resimden 2.
    • Pull the wire coated with dark gray foam out from the space where it is tucked and move it out of the way.
    FixBot'a Sor
    Yorum Ekle
  6. JBL Flip 4 USB Port Replacement: adım 6, 3 resimden 1. JBL Flip 4 USB Port Replacement: adım 6, 3 resimden 2. JBL Flip 4 USB Port Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Unhook the white plug attached to the small circuit board hanging from the gray micro USB casing using the ESD Safe Blunt Nose Tweezers.
    • Move the plug out of the way by pulling it through the gap in the large circuit board to get to the next plug behind it.
    FixBot'a Sor
    Yorum Ekle
  7. JBL Flip 4 USB Port Replacement: adım 7, 2 resimden 1. JBL Flip 4 USB Port Replacement: adım 7, 2 resimden 2.
    • Unhook the other smaller white plug behind the previous plug from the same small hanging circuit board using the tweezers.
    FixBot'a Sor
    Yorum Ekle
  8. JBL Flip 4 USB Port Replacement: adım 8, 1 resimden 1.
    • Pull the gray USB port out of the speaker.
    • Do not yank on this component as it is still attached by wires.
    FixBot'a Sor
    Yorum Ekle
  9. JBL Flip 4 USB Port Replacement: adım 9, 3 resimden 1. JBL Flip 4 USB Port Replacement: adım 9, 3 resimden 2. JBL Flip 4 USB Port Replacement: adım 9, 3 resimden 3.
    • Unhook the small white plug attached to the main circuit board that is holding the USB port to the speaker.
    • Remove the USB port component from the speaker.
    FixBot'a Sor
    Yorum Ekle
  10. JBL Flip 4 USB Port Replacement: adım 10, 2 resimden 1. JBL Flip 4 USB Port Replacement: adım 10, 2 resimden 2.
    • Remove three 9mm Phillips #1 screws holding the two small circuit boards to the USB port component.
    • Pry off the top small circuit board with the plastic opening tool.
    • You will have to use some force to remove this board as it is glued down.
    FixBot'a Sor
    Yorum Ekle
  11. JBL Flip 4 USB Port Replacement: adım 11, 2 resimden 1. JBL Flip 4 USB Port Replacement: adım 11, 2 resimden 2.
    • Peel back the black adhesive on the bottom side of the component with the tweezers and remove the wires underneath.
    • Remove the first small circuit board and attached wires.
    FixBot'a Sor
    Yorum Ekle
  12. JBL Flip 4 USB Port Replacement: adım 12, 2 resimden 1. JBL Flip 4 USB Port Replacement: adım 12, 2 resimden 2.
    • Remove the second circuit board by pulling on it with your hands.
    • You may need to pull hard on this small circuit board as it is also glued in some places.
    FixBot'a Sor
    Yorum Ekle
Sonuç
32 farklı kişi bu kılavuzu tamamladı.
Philip Pang
1.458 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G3, White Fall 2018 Cal Poly, Team S4-G3, White Fall 2018 üyesi
CPSU-WHITE-F18S4G3
4 Üyeler
37 adet Kılavuz yazıldı
12Kılavuz Yorumları
Hi, I need to replace this circuit board where the charging port mounts.
While trying to remove damaged micro usb port, I damaged the tiny wires from the circuit board.
I tried to find this online but no luck so far.
Do you know the code for this PCB?
Thank you,
alex garcia - Yanıt Paylaş
hi, where can i buy new circuit board for micro usb charging port?
joseph celerio - Yanıt Paylaş
please i need 1… thank you.
I have a question on the small circuit board (charge port), one of the female port on it is for power (+5v), but what is another one? Is it D+, D- ?
P.S. I’ve measure that port with micro usb connected to power source, turns out there has no voltage measured, but the bigger one does has 5v measured.
Thanks!
馮會鈞 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 86
Son 30 gün: 433
Her zaman: 74,491
