Giriş
The JBL Flip 1 is an excellent speaker, but we have noticed there are some issues with it. In order to fix these issues, you must first understand how to disassemble the Flip’s outer layers. This guide will teach you how to do this safely and precisely.
Neye ihtiyacın var
On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
12 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
How do i take apart jbl flip 3
The charging PCB on my Flip3 is damaged and needs to be replaced. Any chance of purchasing the charging/interface module, fully populated?
I live in South Africa, and cannot find it here!
Paul M
The charging PCB on my JBL Flip3 is also damaged and needs to be replaced. Any chance of purchasing the charging/interface module?
I live in Pune - Maharashtra in India and cannot find a good reliable service station for JBL speakers here!
Suresh Karve
