Ana içeriğe geç
JBL Go 3 Battery Replacement
Neye ihtiyacın var
  1. JBL Go 3 Battery Replacement, Battery: adım 1, 2 resimden 1. JBL Go 3 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use a Jimmy or opening pick to gently lift one corner of the fabric mesh, then carefully remove the entire fabric and shell.
    • Insert the Jimmy along the seam and gently pry open the housing.
    • Work your way around the speaker, unclipping the internal latches as you go.
  2. JBL Go 3 Battery Replacement: adım 2, 3 resimden 1. JBL Go 3 Battery Replacement: adım 2, 3 resimden 2. JBL Go 3 Battery Replacement: adım 2, 3 resimden 3.
    • Around the rubber circle, you’ll find four small screws.
    • Use a screwdriver to remove the screws.
    • Then gently use a Jimmy to open the speaker’s housing.
  3. JBL Go 3 Battery Replacement: adım 3, 3 resimden 1. JBL Go 3 Battery Replacement: adım 3, 3 resimden 2. JBL Go 3 Battery Replacement: adım 3, 3 resimden 3.
    • Unscrew the motherboard to access the battery.
    • Locate the battery, it’s usually wrapped in black or silver and connected to the mainboard by a small cable.
    • Carefully disconnect the battery connector from the circuit board.
    • Remove the old battery, replace it with the new one and reconnect the cable securely.
    • Close the housing, screw everything back in place, and reattach the fabric mesh.
Sonuç
Kasey Oliver
507 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Konn Spring 2025 UMass Dartmouth, Team 4-5, Konn Spring 2025 üyesi
UMASSD-KONN-S25S4G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 42
Her zaman: 340
