Ana içeriğe geç
JBL Go 3 Charging Port Replacement
Neye ihtiyacın var
  1. JBL Go 3 Charging Port Replacement, Charging Port: adım 1, 3 resimden 1. JBL Go 3 Charging Port Replacement, Charging Port: adım 1, 3 resimden 2. JBL Go 3 Charging Port Replacement, Charging Port: adım 1, 3 resimden 3.
    • Use a Jimmy to remove the hard shell, working around the sides of the mesh cover.
    • Finally, unscrew the internal screws and gently lift off the back panel.
  2. JBL Go 3 Charging Port Replacement: adım 2, 2 resimden 1. JBL Go 3 Charging Port Replacement: adım 2, 2 resimden 2.
    • Locate the charger port on the circuit board.
    • Carefully desolder the old port. If necessary, use an iFixit Opening Tool to gently dislodge and remove it.
  3. JBL Go 3 Charging Port Replacement: adım 3, 3 resimden 1. JBL Go 3 Charging Port Replacement: adım 3, 3 resimden 2. JBL Go 3 Charging Port Replacement: adım 3, 3 resimden 3.
    • Locate the charging port, typically mounted on a small PCB (printed circuit board).
    • Take a picture and make a detailed note of all connections.
    • Carefully remove the charging port using an iFixit Opening Tool if Necessary.
    • Test the charging functionality before fully reassembling the device.
Sonuç
To reassemble your device, carefully place the new charging port and follow the instructions in reverse order.
Kasey Oliver
507 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-5, Konn Spring 2025 UMass Dartmouth, Team 4-5, Konn Spring 2025 üyesi
UMASSD-KONN-S25S4G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 251
