Ana içeriğe geç
JBL Go Repair Motherboard Replacement
Neye ihtiyacın var
  1. JBL Go Repair Motherboard Replacement, Front Cover: adım 1, 1 resimden 1.
    • Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Go Repair Motherboard Replacement: adım 2, 1 resimden 1.
    • Once you have scraped off all of the glue, use the opening tool to pry up the front cover.
    FixBot'a Sor
    Yorum Ekle
  3. JBL Go Repair Motherboard Replacement: adım 3, 1 resimden 1.
    • Carefully remove the loose plastic cover from the speaker.
    FixBot'a Sor
    Yorum Ekle
  4. JBL Go Repair Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Once the front cover is removed, use a T6 screwdriver to remove the four 9 mm screws on the black cover.
    FixBot'a Sor
    Yorum Ekle
  5. JBL Go Repair Motherboard Replacement: adım 5, 1 resimden 1.
    • After removing the screws, use the plastic opening tool to carefully pry around the edges of the black cover to loosen and lift the cover off of the device.
    FixBot'a Sor
    Yorum Ekle
  6. JBL Go Repair Motherboard Replacement: adım 6, 1 resimden 1.
    • Carefully unplug the woofer wires from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. JBL Go Repair Motherboard Replacement: adım 7, 1 resimden 1.
    • Use the T6 screwdriver to remove the 9 mm screw that secures the motherboard in place.
    FixBot'a Sor
    Yorum Ekle
  8. JBL Go Repair Motherboard Replacement: adım 8, 1 resimden 1.
    • Lift the motherboard using the plastic opening tool and stick it through the hole in the middle of the board.
    FixBot'a Sor
    Yorum Ekle
  9. JBL Go Repair Motherboard Replacement: adım 9, 1 resimden 1.
    • Carefully lift the motherboard, sliding the charging port side out of the frame of the speaker as you go.
    FixBot'a Sor
    Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Sydney Jason
854 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 35
Son 30 gün: 159
Her zaman: 6,452
