Ana içeriğe geç
JBL Go Woofer Replacement
Neye ihtiyacın var
  1. JBL Go Woofer Replacement, Front Cover: adım 1, 1 resimden 1.
    • Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Go Woofer Replacement: adım 2, 1 resimden 1.
    • Once you have scraped off all of the glue, use the opening tool to pry up the front cover.
    FixBot'a Sor
    Yorum Ekle
  3. JBL Go Woofer Replacement: adım 3, 1 resimden 1.
    • Carefully remove the loose plastic cover from the speaker.
    FixBot'a Sor
    Yorum Ekle
  4. JBL Go Woofer Replacement, Woofer: adım 4, 2 resimden 1. JBL Go Woofer Replacement, Woofer: adım 4, 2 resimden 2.
    • Once the front cover is removed, use a T6 screwdriver head to remove the four 9 mm screws on the black cover.
    FixBot'a Sor
    Yorum Ekle
  5. JBL Go Woofer Replacement: adım 5, 1 resimden 1.
    • After removing the screws, use the plastic opening tool to carefully pry around the edges of the black cover to loosen and lift the cover off of the device.
    FixBot'a Sor
    Yorum Ekle
  6. JBL Go Woofer Replacement: adım 6, 1 resimden 1.
    • Carefully unplug the woofer wires from the motherboard
    FixBot'a Sor
    Yorum Ekle
  7. JBL Go Woofer Replacement: adım 7, 1 resimden 1.
    • Once the black cover is fully detached from the speaker, unscrew the woofer from the back of the black cover using a T6 screwdriver head.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sydney Jason
854 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 92
Her zaman: 4,116
