Giriş
This guide will walk you through replacing the driver if your JBL Grip speaker is not producing audio. Before starting, make sure the speaker is powered off and disconnected from any external cables. Handle all internal parts carefully to avoid damaging sensitive components.
Neye ihtiyacın var
Remove the four 3mm screws securing the speaker cover with a Phillips #2 screwdriver. Pry the speaker assembly from the body with the plastic pry tool.
Pry the speaker assembly from the body with an opening tool.
