Ana içeriğe geç
JBL L26 Speaker Replacement
Neye ihtiyacın var
  1. JBL L26 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Remove the four 6.4 mm Phillips #2 screws from the front of the speaker.
  2. JBL L26 Speaker Replacement: adım 2, 1 resimden 1.
    • Pull the speaker out of the frame and lay it onto the side.
  3. JBL L26 Speaker Replacement: adım 3, 1 resimden 1.
    • Unlatch the green wire by pulling on the terminal connector and not the wire.
  4. JBL L26 Speaker Replacement: adım 4, 2 resimden 1. JBL L26 Speaker Replacement: adım 4, 2 resimden 2.
    • Use a small prying tool to pry the terminal connector off of the tap.
    • After you unlatched both edges, pull the black wire out.
  5. JBL L26 Speaker Replacement: adım 5, 1 resimden 1.
    • Get your replacement speaker and connect the green wire by pushing the terminal connector onto the tap.
  6. JBL L26 Speaker Replacement: adım 6, 2 resimden 1. JBL L26 Speaker Replacement: adım 6, 2 resimden 2.
    • Connect the black wire by attaching the terminal connector onto the tap.
    • Use a clamping tool to clip the edges toward the tap.
    • Be careful not to clamp too hard so you don't damage the tap.
  7. JBL L26 Speaker Replacement: adım 7, 1 resimden 1.
    • Place the new speaker onto the frame and screw the four 6.4 mm Phillips #2 screws back in.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nathnael Dubale
269 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 1,070
