Ana içeriğe geç
JBL On Stage II 30-Pin Connector Replacement
Neye ihtiyacın var
  1. JBL On Stage II 30-Pin Connector Replacement, Cracking the Case: adım 1, 1 resimden 1.
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II 30-Pin Connector Replacement: adım 2, 1 resimden 1.
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II 30-Pin Connector Replacement: adım 3, 1 resimden 1.
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II 30-Pin Connector Replacement: adım 4, 2 resimden 1. JBL On Stage II 30-Pin Connector Replacement: adım 4, 2 resimden 2.
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II 30-Pin Connector Replacement: adım 5, 3 resimden 1. JBL On Stage II 30-Pin Connector Replacement: adım 5, 3 resimden 2. JBL On Stage II 30-Pin Connector Replacement: adım 5, 3 resimden 3.
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II 30-Pin Connector Replacement: adım 6, 1 resimden 1.
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II 30-Pin Connector Replacement: adım 7, 2 resimden 1. JBL On Stage II 30-Pin Connector Replacement: adım 7, 2 resimden 2.
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  8. JBL On Stage II 30-Pin Connector Replacement, 30-Pin Connector Replacement: adım 8, 1 resimden 1.
    • Apply heat with a heatgun on a low setting to the area around the 30-pin connector until you can easily pry it out by the seam surrounding it (about 10 minutes).
  9. JBL On Stage II 30-Pin Connector Replacement: adım 9, 1 resimden 1.
    • Use a metal spudger to pry out the plastic surrounding the 30-pin connector.
  10. JBL On Stage II 30-Pin Connector Replacement: adım 10, 1 resimden 1.
    • Use a pair of tweezers to wiggle out the 30-pin connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Janessa D Cabrera
514 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-28, Maness Winter 2014 Cal Poly, Team 9-28, Maness Winter 2014 üyesi
CPSU-MANESS-W14S9G28
4 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
and how you get a new one of the 30 pin connector?
bini barazany - Yanıt
Yes, where can we buy a new one of the 30 pin connector?
Jimbo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 4,426
