Giriş
First, the device will need to be cracked open. After, you will remove the damaged speakers and replace them with new, working speakers.
Neye ihtiyacın var
Turn the device upside down so that the three rubber pads are facing up.
To reassemble your device, follow these directions in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Where can I buy the replacement speaker?
I join Gןilberto question,can someone attach a link to replacement speakers or tell what is the p/n of the speakers ?
Thanks !
little bit late i just order it after 2 years searching
Do these work as original driver are 8 ohm?
