Giriş
First, the device will need to be cracked open. After, you will remove the damaged speakers and replace them with new, working speakers.
Neye ihtiyacın var
Turn the device upside down so that the three rubber pads are facing up.
Cut the black wire (leading to the speaker you are replacing) with a pair of wire cutters.
Cut the red wire (leading to the speaker you are replacing) with a pair of wire cutters.
just pull of the plug, no need to cut the wires
To reassemble your device, follow these directions in reverse order.
5 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Where can I buy the replacement speaker?
I join Gןilberto question,can someone attach a link to replacement speakers or tell what is the p/n of the speakers ?
Thanks !
little bit late i just order it after 2 years searching
Do these work as original driver are 8 ohm?
Where can i buy these speakers (3w-8 omhns)?
My JBL "on Stage III" Ipod Sound Dock with remote - World Wide Voltage speakers r all damage, i want a new spaekars, how can i get his.
How to find these component speaker
My jbl stage 2 speaker is broke
I want to buy new ones but i did not find them
Let me know if u arrange
