Giriş
If you experience any difficulties with charging or playing music through an auxiliary cable, you may need to replace your JBL Pulse 2 speaker's auxiliary and micro USB ports.
Neye ihtiyacın var
Remove the rubber rings from either end of the device.
If there is difficulty in lifting the rings from the device, use the metal spudger.
Bu adımda kullanılan alet:Tweezers$3.99
Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
Remove the solder on the micro USB and Auxiliary port wires to disconnect them.
15 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Is there a video out there to demonstrate this repair process?
Hallo, suche für die “JBL pulse 2” die Bauteile FB5 und D9 auf dem Mainboard.
Wer kennt diese Bauteile ?
Würde mich auf eine positive Antwort freuen.
Liebe Grüße J.R.
Bonjour pourriez-vous me dire ou acheter cette petite carte électronique merci.
