Ana içeriğe geç
JBL Pulse 2 Battery Replacement
Neye ihtiyacın var
  1. JBL Pulse 2 Battery Replacement, Battery: adım 1, 2 resimden 1. JBL Pulse 2 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Battery Replacement: adım 4, 2 resimden 1. JBL Pulse 2 Battery Replacement: adım 4, 2 resimden 2.
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Battery Replacement: adım 5, 3 resimden 1. JBL Pulse 2 Battery Replacement: adım 5, 3 resimden 2. JBL Pulse 2 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Battery Replacement: adım 7, 2 resimden 1. JBL Pulse 2 Battery Replacement: adım 7, 2 resimden 2.
    • Unlatch the mechanism holding the ribbon wires in place, then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Battery Replacement: adım 8, 2 resimden 1. JBL Pulse 2 Battery Replacement: adım 8, 2 resimden 2.
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
  9. JBL Pulse 2 Battery Replacement: adım 9, 2 resimden 1. JBL Pulse 2 Battery Replacement: adım 9, 2 resimden 2.
    • Remove the four 7.9mm Phillips #1 screws around the edges of the center piece.
    • Slide the outer casing off away from the auxiliary and micro USB port.
  10. JBL Pulse 2 Battery Replacement: adım 10, 1 resimden 1.
    • Remove the other end of the device to access the wiring underneath it.
  11. JBL Pulse 2 Battery Replacement: adım 11, 1 resimden 1.
    Bu adımda kullanılan alet:
    $3.99
    • Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
  12. JBL Pulse 2 Battery Replacement: adım 12, 1 resimden 1.
    • Remove the four 7.9mm Phillips #1 screws from the black centerpiece of the device.
  13. JBL Pulse 2 Battery Replacement: adım 13, 2 resimden 1. JBL Pulse 2 Battery Replacement: adım 13, 2 resimden 2.
    • Use the spudger to reach under the sides of the black centerpiece to access the six latches, three of which are on each side.
  14. JBL Pulse 2 Battery Replacement: adım 14, 2 resimden 1. JBL Pulse 2 Battery Replacement: adım 14, 2 resimden 2.
    • Lift the black centerpiece off with the metal spudger to reveal the battery underneath.
  15. JBL Pulse 2 Battery Replacement: adım 15, 1 resimden 1.
    • Use a hot air gun to soften the hot glue in order to fully remove the battery.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 18
Son 30 gün: 73
Her zaman: 9,525
