Ana içeriğe geç
JBL Pulse 2 Button Circuit Board Replacement
Neye ihtiyacın var
  1. JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: adım 1, 2 resimden 1. JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: adım 1, 2 resimden 2.
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Button Circuit Board Replacement: adım 2, 1 resimden 1.
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Button Circuit Board Replacement: adım 3, 1 resimden 1.
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Button Circuit Board Replacement: adım 4, 2 resimden 1. JBL Pulse 2 Button Circuit Board Replacement: adım 4, 2 resimden 2.
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Button Circuit Board Replacement: adım 5, 3 resimden 1. JBL Pulse 2 Button Circuit Board Replacement: adım 5, 3 resimden 2. JBL Pulse 2 Button Circuit Board Replacement: adım 5, 3 resimden 3.
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Button Circuit Board Replacement: adım 6, 1 resimden 1.
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Button Circuit Board Replacement: adım 7, 2 resimden 1. JBL Pulse 2 Button Circuit Board Replacement: adım 7, 2 resimden 2.
    • Unlatch the mechanism holding the ribbon wires in place then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Button Circuit Board Replacement: adım 8, 2 resimden 1. JBL Pulse 2 Button Circuit Board Replacement: adım 8, 2 resimden 2.
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
3 Yorum
where can I buy that part
Wilco Peters - Yanıt
I love you guys
Davi Dodo - Yanıt
I need to buy parts
hernzum - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,101
