Ana içeriğe geç
JBL Pulse 3 LED Light Display Replacement
Neye ihtiyacın var
  1. JBL Pulse 3 LED Light Display Replacement, Speaker Grill: adım 1, 1 resimden 1.
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Pulse 3 LED Light Display Replacement: adım 2, 1 resimden 1.
    • Repeat step 1 for bottom right corner of speaker grill.
    FixBot'a Sor
    Yorum Ekle
  3. JBL Pulse 3 LED Light Display Replacement: adım 3, 2 resimden 1. JBL Pulse 3 LED Light Display Replacement: adım 3, 2 resimden 2.
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    FixBot'a Sor
    Yorum Ekle
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
    FixBot'a Sor
    Yorum Ekle
  4. JBL Pulse 3 LED Light Display Replacement, Outside Casing: adım 5, 2 resimden 1. JBL Pulse 3 LED Light Display Replacement, Outside Casing: adım 5, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
    FixBot'a Sor
    Yorum Ekle
  5. JBL Pulse 3 LED Light Display Replacement: adım 6, 2 resimden 1. JBL Pulse 3 LED Light Display Replacement: adım 6, 2 resimden 2.
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
    FixBot'a Sor
    Yorum Ekle
  6. JBL Pulse 3 LED Light Display Replacement: adım 7, 2 resimden 1. JBL Pulse 3 LED Light Display Replacement: adım 7, 2 resimden 2.
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. JBL Pulse 3 LED Light Display Replacement: adım 8, 1 resimden 1.
    • Pull off the top disc of the JBL Pulse 3.
    FixBot'a Sor
    Yorum Ekle
  8. JBL Pulse 3 LED Light Display Replacement: adım 9, 2 resimden 1. JBL Pulse 3 LED Light Display Replacement: adım 9, 2 resimden 2.
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. JBL Pulse 3 LED Light Display Replacement: adım 10, 2 resimden 1. JBL Pulse 3 LED Light Display Replacement: adım 10, 2 resimden 2.
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
    FixBot'a Sor
    Yorum Ekle
  10. JBL Pulse 3 LED Light Display Replacement: adım 11, 1 resimden 1.
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
    FixBot'a Sor
    Yorum Ekle
  11. JBL Pulse 3 LED Light Display Replacement, LED Light Display: adım 12, 3 resimden 1. JBL Pulse 3 LED Light Display Replacement, LED Light Display: adım 12, 3 resimden 2. JBL Pulse 3 LED Light Display Replacement, LED Light Display: adım 12, 3 resimden 3.
    • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
    • Pull the LED light display off of the JBL Pulse 3 base.
    FixBot'a Sor
    Yorum Ekle
  12. JBL Pulse 3 LED Light Display Replacement: adım 13, 2 resimden 1. JBL Pulse 3 LED Light Display Replacement: adım 13, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to pull the five connections off of the LED light display.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Hello,I really need some code to show me how to initialize and LED display and how to output data from it.Any help is much appreciated.
Osama Siddiq - Yanıt Paylaş
Wow jbl
Gyyzhuahyz8yus
Majd Tom - Yanıt Paylaş
Where to buy the leds?
mj.viana1993 - Yanıt Paylaş
Hello i need an assitance in a LED screen manufacturing
volkanoo - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 49
Her zaman: 4,220
