Ana içeriğe geç
JBL Pulse 3 Motherboard Replacement
Neye ihtiyacın var
  1. JBL Pulse 3 Motherboard Replacement, Speaker Grill: adım 1, 1 resimden 1.
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Pulse 3 Motherboard Replacement: adım 2, 1 resimden 1.
    • Repeat step 1 for bottom right corner of speaker grill.
    FixBot'a Sor
    Yorum Ekle
  3. JBL Pulse 3 Motherboard Replacement: adım 3, 2 resimden 1. JBL Pulse 3 Motherboard Replacement: adım 3, 2 resimden 2.
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    FixBot'a Sor
    Yorum Ekle
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
    FixBot'a Sor
    Yorum Ekle
  4. JBL Pulse 3 Motherboard Replacement, Outside Casing: adım 5, 2 resimden 1. JBL Pulse 3 Motherboard Replacement, Outside Casing: adım 5, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
    FixBot'a Sor
    Yorum Ekle
  5. JBL Pulse 3 Motherboard Replacement: adım 6, 2 resimden 1. JBL Pulse 3 Motherboard Replacement: adım 6, 2 resimden 2.
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
    FixBot'a Sor
    Yorum Ekle
  6. JBL Pulse 3 Motherboard Replacement: adım 7, 2 resimden 1. JBL Pulse 3 Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. JBL Pulse 3 Motherboard Replacement: adım 8, 1 resimden 1.
    • Pull off the top disc of the JBL Pulse 3.
    FixBot'a Sor
    Yorum Ekle
  8. JBL Pulse 3 Motherboard Replacement: adım 9, 2 resimden 1. JBL Pulse 3 Motherboard Replacement: adım 9, 2 resimden 2.
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. JBL Pulse 3 Motherboard Replacement: adım 10, 2 resimden 1. JBL Pulse 3 Motherboard Replacement: adım 10, 2 resimden 2.
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
    FixBot'a Sor
    Yorum Ekle
  10. JBL Pulse 3 Motherboard Replacement: adım 11, 1 resimden 1.
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
    FixBot'a Sor
    Yorum Ekle
  11. JBL Pulse 3 Motherboard Replacement, LED Light Display: adım 12, 3 resimden 1. JBL Pulse 3 Motherboard Replacement, LED Light Display: adım 12, 3 resimden 2. JBL Pulse 3 Motherboard Replacement, LED Light Display: adım 12, 3 resimden 3.
    • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
    • Pull the LED light display off of the JBL Pulse 3 base.
    FixBot'a Sor
    Yorum Ekle
  12. JBL Pulse 3 Motherboard Replacement: adım 13, 2 resimden 1. JBL Pulse 3 Motherboard Replacement: adım 13, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to pull the five connections off of the LED light display.
    FixBot'a Sor
    Yorum Ekle
  13. JBL Pulse 3 Motherboard Replacement, Motherboard: adım 14, 2 resimden 1. JBL Pulse 3 Motherboard Replacement, Motherboard: adım 14, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
    FixBot'a Sor
    Yorum Ekle
  14. JBL Pulse 3 Motherboard Replacement: adım 15, 3 resimden 1. JBL Pulse 3 Motherboard Replacement: adım 15, 3 resimden 2. JBL Pulse 3 Motherboard Replacement: adım 15, 3 resimden 3.
    • Pull out the motherboard slightly from the LED light display as shown. Using tweezers, unplug the three connections attached to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  15. JBL Pulse 3 Motherboard Replacement: adım 16, 1 resimden 1.
    • Pull the rest of the motherboard out from the LED light display.
    • Using wire cutters, snip the black wire connecting to the base of the JBL Pulse 3 at the base of the motherboard. The motherboard should now be removed from the JBL Pulse 3.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Note: To replace the motherboard, you will need to re-solder the black wire to the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
tengo un pulse 3 que la placa entro en corto… me gustaria saber si alguien me puede ayudar con el diagrama esquematico o algun foto donde pueda conseguir
Wilson Flores - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 60
Her zaman: 4,622
