Giriş
If your JBL Pulse 4 Bluetooth speaker has distorted sound, low volume, or no sound at all, this guide will show you how to replace the internal speaker drivers.
The speaker drivers are the parts that create sound. If they stop working, you might hear buzzing, crackling, or nothing at all. To reach them, you’ll need to take apart the speaker by removing the outer casing, LED display, battery, and motherboard.
Before starting, make sure the problem isn’t due to a Bluetooth connection or software issue. Try restarting the speaker and connecting it to different devices.
Be sure the speaker is powered off and unplugged before starting. If the battery looks swollen or damaged, don’t continue the repair. It’s also a good idea to work in a clean, static-safe area to avoid damaging any parts.
Neye ihtiyacın var
Power off the device before doing any repairs.
Hold the power button for 3+ seconds to power down the device.
Place the speaker on the table with the button board side down.
Remove the three black 5 mm screws using a Phillips #1 screwdriver.
Remove the white casing by pulling it away from the button board.
Cut the black cable off the motherboard using cutters to remove the button board.
Bu adımda kullanılan alet:Tweezers$4.99
Using the tweezers, gently unplug the three connections attached to the motherboard.
Use a Phillips #00 screwdriver to remove the three 5 mm screws securing the plastic housing.
Remove the bumper assembly.
