Ana içeriğe geç
JBL Pulse LED Light Replacement
Neye ihtiyacın var
    1. JBL Pulse LED Light Replacement, Button Board: adım 1, 1 resimden 1.
      • Use a plastic opening tool to pry around the edges of the circular rubber panel.
      FixBot'a Sor
      Yorum Ekle
    2. JBL Pulse LED Light Replacement: adım 2, 1 resimden 1.
      • Once the edges are loose, pull off the rubber button panel completely.
      • New adhesive will have to be applied when reassembling.
      FixBot'a Sor
      Yorum Ekle
    3. JBL Pulse LED Light Replacement: adım 3, 1 resimden 1.
      • Use your plastic opening tool to pry the button board loose by lifting the edges.
      FixBot'a Sor
      Yorum Ekle
    4. JBL Pulse LED Light Replacement: adım 4, 1 resimden 1.
      • Lift the button board, exposing the attached cable.
      FixBot'a Sor
      Yorum Ekle
    5. JBL Pulse LED Light Replacement: adım 5, 1 resimden 1.
      • Pull black piece on top of socket away from board to loosen, then detach the cable.
      FixBot'a Sor
      Yorum Ekle
    1. JBL Pulse LED Light Replacement, Outer Casing: adım 6, 3 resimden 1. JBL Pulse LED Light Replacement, Outer Casing: adım 6, 3 resimden 2. JBL Pulse LED Light Replacement, Outer Casing: adım 6, 3 resimden 3.
      • Take out the four 9mm black PH0 screws from the top and bottom of the device.
      • Pull off cap by hand.
      • The outer casing can now be removed.
      FixBot'a Sor
      Yorum Ekle
    1. JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: adım 7, 2 resimden 1. JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: adım 7, 2 resimden 2.
      • Remove the tape around the cables on the top of the device.
      • Remove the cables by lifting up on the black bracket and then pulling the cable out.
      FixBot'a Sor
      Yorum Ekle
    1. JBL Pulse LED Light Replacement, LED Light: adım 8, 1 resimden 1.
      • Pry off LED light panel using a metal spudger.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Maxwell Busenbarrick
1.401 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 18-6, Blackwell Fall 2016 USF Tampa, Team 18-6, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S18G6
3 Üyeler
20 adet Kılavuz yazıldı
1Rehber Yorum
Were do I buy a Replacement led strip?
Jalen6988 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 3,825
