Ana içeriğe geç
JBL Pulse Motherboard Replacement
Neye ihtiyacın var
  1. JBL Pulse Motherboard Replacement, Button Board: adım 1, 1 resimden 1.
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Pulse Motherboard Replacement: adım 2, 1 resimden 1.
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
    FixBot'a Sor
    Yorum Ekle
  3. JBL Pulse Motherboard Replacement: adım 3, 1 resimden 1.
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
    FixBot'a Sor
    Yorum Ekle
  4. JBL Pulse Motherboard Replacement: adım 4, 1 resimden 1.
    • Lift the button board, exposing the attached cable.
    FixBot'a Sor
    Yorum Ekle
  5. JBL Pulse Motherboard Replacement: adım 5, 1 resimden 1.
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
    FixBot'a Sor
    Yorum Ekle
  6. JBL Pulse Motherboard Replacement, Outer Casing: adım 6, 3 resimden 1. JBL Pulse Motherboard Replacement, Outer Casing: adım 6, 3 resimden 2. JBL Pulse Motherboard Replacement, Outer Casing: adım 6, 3 resimden 3.
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
    FixBot'a Sor
    Yorum Ekle
  7. JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: adım 7, 2 resimden 1. JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: adım 7, 2 resimden 2.
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
    FixBot'a Sor
    Yorum Ekle
  8. JBL Pulse Motherboard Replacement, JBL Pulse Disassembly: adım 8, 1 resimden 1.
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
    FixBot'a Sor
    Yorum Ekle
  9. JBL Pulse Motherboard Replacement: adım 9, 3 resimden 1. JBL Pulse Motherboard Replacement: adım 9, 3 resimden 2. JBL Pulse Motherboard Replacement: adım 9, 3 resimden 3.
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
    FixBot'a Sor
    Yorum Ekle
  10. JBL Pulse Motherboard Replacement: adım 10, 2 resimden 1. JBL Pulse Motherboard Replacement: adım 10, 2 resimden 2.
    • Remove cables by pulling firmly.
    FixBot'a Sor
    Yorum Ekle
  11. JBL Pulse Motherboard Replacement, Motherboard: adım 11, 1 resimden 1.
    • Once all of the cables are removed, grip the motherboard and slide it out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Maxwell Busenbarrick
1.401 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 18-6, Blackwell Fall 2016 USF Tampa, Team 18-6, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S18G6
3 Üyeler
13 adet Kılavuz yazıldı
3Kılavuz Yorumları
Excelente, funcionó perfectamente la guia. Compré la bateria y el armado funcionó perfecto. Muchas gracias.
Angel Pérez - Yanıt Paylaş
my usb port is damaged. Do I have to replace the whole motherboarD?
dinosdabi - Yanıt Paylaş
Hey I need JBL pulse motherboard Where can I buy. Please help
kashyapvikas228vk1070301 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 52
Her zaman: 10,200
