Giriş
This guide shows how to replace the speaker inside of the device. Replacing the speakers is only necessary if the device is playing distorted or no audio.
Neye ihtiyacın var
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Take out the four 9mm black PH0 screws from the top and bottom of the device.
Pull off cap by hand.
The outer casing can now be removed.
Remove the tape around the cables on the top of the device.
Remove the cables by lifting up on the black bracket and then pulling the cable out.
Remove two black 9mm PH0 screws from outside of inner casing on each side.
Remove four black PH0 9mm screws.
The only thing still attaching the speakers is the wires to the soldering points. Cut wires at soldering points.
6 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Hi,
Thanks for your guide. Where did you obtain replacement speakers?
Hi. Even I would like to know a good replacement/ substitute speaker for this. Thanks
Hi.
Even I would like to know where I can find a replacement or an alternate speaker..
Could you please share any links to buy these spare speakers ..Thanks in advance ☺️
