Ana içeriğe geç
JBL Spyro/Spot Partial Disassembly
Neye ihtiyacın var
  1. JBL Spyro/Spot Partial Disassembly, Locate the risers: adım 1, 1 resimden 1.
    • Locate the 3 risers the hold the base plate in place
  2. JBL Spyro/Spot Partial Disassembly, Pry the plugs from the risers: adım 2, 1 resimden 1.
    • Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
  3. JBL Spyro/Spot Partial Disassembly, Remove the base plate: adım 3, 1 resimden 1.
    • With all three loosened remove the base!
    • Note the not equilateral placement of the risers when replacing the base.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Ryan McLeod
606 İtibar
2 adet Kılavuz yazıldı
11 Yorum
Thanks, so nice tip. I'll see if I can find a similar speaker, big hug.
durval - Yanıt
No problem!!
Ryan McLeod -
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
pszopa - Yanıt
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
Ryan McLeod -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 17
Son 30 gün: 105
Her zaman: 13,032
