Ana içeriğe geç
JBL Wave Beam Case Disassembly
Neye ihtiyacın var
  1. JBL Wave Beam Case Disassembly, Heat up the case: adım 1, 1 resimden 1.
    • Open up your case and remove the earbuds. Prepare a heat gun at around 150℃, and gently heat up the front part of the case, around where the LED is.
    FixBot'a Sor
    Yorum Ekle
  2. JBL Wave Beam Case Disassembly, Insert a plastic pick: adım 2, 2 resimden 1. JBL Wave Beam Case Disassembly, Insert a plastic pick: adım 2, 2 resimden 2.
    • Now try to insert an opening pick into the seam as shown. If you can't get it in, try heating the case more or using a different pick.
    • Slide the pick around the edge of the case until it reaches the back, next to the hinge part. You can apply more heat here if this is too difficult.
    • Repeat with a second opening pick, going round the other side. The second image shows what your case should now look like.
    FixBot'a Sor
    Yorum Ekle
  3. JBL Wave Beam Case Disassembly, Lift out the internals: adım 3, 1 resimden 1.
    • Use a plastic tool to lift up the internals as shown
    • If this is too difficult, you might want to use a third pick, and pry around the area under the LED.
    FixBot'a Sor
    Yorum Ekle
  4. JBL Wave Beam Case Disassembly, Remove the electronics: adım 4, 2 resimden 1. JBL Wave Beam Case Disassembly, Remove the electronics: adım 4, 2 resimden 2.
    • You should now have removed the outer case. Remove the two Phillips #0 screws next to the exposed USB port.
    • Pull the motherboard directly upwards. Be gentle here, as it is still connected to the glued-down battery
    • Use a plastic tool to pry out the battery, it is attached to the case with a sticky pad. If you have isopropyl alcohol, apply some underneath the battery to loosen the adhesive.
    FixBot'a Sor
    Yorum Ekle
  5. JBL Wave Beam Case Disassembly, Desolder the battery: adım 5, 1 resimden 1.
    • The battery is connected to the motherboard with either 3 or 2 solder pads. Use a soldering iron and flux to remove all of them, being careful not to cause any shorts.
    FixBot'a Sor
    Yorum Ekle
    • Solder the black and red wires of your new battery to GND and BATT on the motherboard, respectively. If there is a third wire (temperature sensor) solder it to the NTC pad.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chris P. Croutonne
1.208 İtibar
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 93
Son 30 gün: 409
Her zaman: 2,638
