Giriş
Taking off the cover is a prerequisite to most repairs barring the battery replacement. Using a standoff screwdriver and spudger should be all you need.
Take care to use the correct orientation when trying to pry off the cover. If you try to loosen the wrong side you could risk breaking the retaining clip holding it down.
Neye ihtiyacın var
Insert the flat end of a spudger into the mesh cover seam beside the battery compartment.
Pry on both sides of the battery compartment until the mesh cover releases.
Bir başkası bu kılavuzu tamamladı.
