Ana içeriğe geç
JBL Xtreme Bass Radiator Replacement
Neye ihtiyacın var
  1. JBL Xtreme Bass Radiator Replacement, Cover: adım 1, 1 resimden 1.
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Bass Radiator Replacement: adım 2, 2 resimden 1. JBL Xtreme Bass Radiator Replacement: adım 2, 2 resimden 2.
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Bass Radiator Replacement: adım 3, 2 resimden 1. JBL Xtreme Bass Radiator Replacement: adım 3, 2 resimden 2.
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Bass Radiator Replacement, Bass Radiator: adım 4, 3 resimden 1. JBL Xtreme Bass Radiator Replacement, Bass Radiator: adım 4, 3 resimden 2. JBL Xtreme Bass Radiator Replacement, Bass Radiator: adım 4, 3 resimden 3.
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Bass Radiator Replacement: adım 5, 3 resimden 1. JBL Xtreme Bass Radiator Replacement: adım 5, 3 resimden 2. JBL Xtreme Bass Radiator Replacement: adım 5, 3 resimden 3.
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Benny Huynh
1.953 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Sullivan Spring 2017 USF Tampa, Team 1-1, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S1G1
4 Üyeler
27 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 71
Her zaman: 20,635
