Ana içeriğe geç
JBL Xtreme Cover Disassembly
Neye ihtiyacın var
  1. JBL Xtreme Cover Disassembly, Cover: adım 1, 1 resimden 1.
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Cover Disassembly: adım 2, 2 resimden 1. JBL Xtreme Cover Disassembly: adım 2, 2 resimden 2.
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Cover Disassembly: adım 3, 2 resimden 1. JBL Xtreme Cover Disassembly: adım 3, 2 resimden 2.
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Benny Huynh
1.953 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Sullivan Spring 2017 USF Tampa, Team 1-1, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S1G1
4 Üyeler
27 adet Kılavuz yazıldı
5 Yorum
Can you fix my cover on speaker
c_pg08 - Yanıt
where can I find a new cover for xtreme 2, if possible in black?
vale0501 - Yanıt
If you find a place to buy a cover let me know
abjayaman -
you forgot about 2 screws
Enescu Catalin - Yanıt
zapomniałeś o śrubach osoby które o tym mogły nie wiedzieć mogły urwać plastikowy haczyk który utrzymuje przód
megakacper11 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 50
Son 30 gün: 199
Her zaman: 30,568
