Ana içeriğe geç
JD Razor 2000 Back Wheel Replacement
Neye ihtiyacın var
  1. JD Razor 2000 Back Wheel Replacement, Unscrewing the Axle Bolt: adım 1, 2 resimden 1. JD Razor 2000 Back Wheel Replacement, Unscrewing the Axle Bolt: adım 1, 2 resimden 2.
    • Facing the wheelie bar as shown, place your left thumb on the bolt located on the left side of the back wheel and place the Allen wrench into the screw on the right side of the back wheel.
    • Using the wrench, slowly unscrew the bolt while applying constant pressure from the left side.
    FixBot'a Sor
    Yorum Ekle
  2. JD Razor 2000 Back Wheel Replacement, Removing the Bolt and Bearing: adım 2, 2 resimden 1. JD Razor 2000 Back Wheel Replacement, Removing the Bolt and Bearing: adım 2, 2 resimden 2.
    • Remove the bolt from the right side and the bearing from the left.
    FixBot'a Sor
    Yorum Ekle
  3. JD Razor 2000 Back Wheel Replacement, Removing the Wheel: adım 3, 1 resimden 1.
    • Turn the JD Razor 2000 on its side as shown. Slowly remove the back wheel by pulling it out at a perpendicular angle to the scooter base.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Eric Johnson
311 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S4G46
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 46
Her zaman: 1,315
