Ana içeriğe geç
JD Razor 2000 Front Wheel Replacement
Neye ihtiyacın var
  1. JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: adım 1, 3 resimden 1. JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: adım 1, 3 resimden 2. JD Razor 2000 Front Wheel Replacement, Removing the 1.75" Axle Bolt: adım 1, 3 resimden 3.
    • Orient the scooter so that the front wheel is facing you. Observe the right and left side of the wheel. Remember which is which throughout the guide.
    • Using an Allen wrench, unscrew the axle bolt slowly from the right side while applying a constant pressure with your hand on the left side of the bearing.
    • If the left side of the bolt turns while you unscrew the right side, you will need to use a second Allen wrench to prevent it from moving
    • If the bolt does not move at all, or moves very little, try applying a lubricant on as much of the screw as possible and try again in 5 minutes.
    • Carefully pull apart the bolt and bearing from either side of the wheel.
  2. JD Razor 2000 Front Wheel Replacement, Removing the Wheel: adım 2, 1 resimden 1.
    • Grip the bottom of the wheel and gently slide it out.
Sonuç
Kaylan Naicker
255 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S4G46
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 1,137
