Ana içeriğe geç
JD Razor 2000 T-Bar Replacement
Neye ihtiyacın var
  1. JD Razor 2000 T-Bar Replacement, Unlocking the Lever: adım 1, 2 resimden 1. JD Razor 2000 T-Bar Replacement, Unlocking the Lever: adım 1, 2 resimden 2.
    • Unlock the quick-release lever by turning the lever from a tightened position.
  2. JD Razor 2000 T-Bar Replacement, Loosening the Screw: adım 2, 3 resimden 1. JD Razor 2000 T-Bar Replacement, Loosening the Screw: adım 2, 3 resimden 2. JD Razor 2000 T-Bar Replacement, Loosening the Screw: adım 2, 3 resimden 3.
    • Use a 7/32" Allen Wrench or T25 Screwdriver to loosen the screw shown.
    • Be sure to fasten the opposite side of the screw before unscrewing.
    • Remove the screw and note the order of the parts for reassembly.
  3. JD Razor 2000 T-Bar Replacement, Removing the Latch: adım 3, 3 resimden 1. JD Razor 2000 T-Bar Replacement, Removing the Latch: adım 3, 3 resimden 2. JD Razor 2000 T-Bar Replacement, Removing the Latch: adım 3, 3 resimden 3.
    • Turn the quick-release lever over to reveal an 8mm screw.
    • Use the Phillips #2 screw driver to remove the screw.
    • After removing the screw, the circular latch will be detachable.
  4. JD Razor 2000 T-Bar Replacement, Remove the T-Bar: adım 4, 1 resimden 1.
    • After disassembling the Quick-Release Lever, the T-Bar is removable
Sonuç
Shane
384 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S4G46
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 779
