Ana içeriğe geç
JIAYU F1 Battery Replacement
Neye ihtiyacın var
  1. JIAYU F1 Battery Replacement, Turn Off the Phone: adım 1, 1 resimden 1.
    • Turn the phone off by holding down the power button located on the top of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. JIAYU F1 Battery Replacement, Remove the Back Case: adım 2, 3 resimden 1. JIAYU F1 Battery Replacement, Remove the Back Case: adım 2, 3 resimden 2. JIAYU F1 Battery Replacement, Remove the Back Case: adım 2, 3 resimden 3.
    • Find the small indentation at the bottom right of the phone and pry open the back case of the phone using your fingernail or small plastic opening tool.
    • Gently remove the back case completely from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. JIAYU F1 Battery Replacement, Remove the Battery: adım 3, 3 resimden 1. JIAYU F1 Battery Replacement, Remove the Battery: adım 3, 3 resimden 2. JIAYU F1 Battery Replacement, Remove the Battery: adım 3, 3 resimden 3.
    • Insert a fingernail or the small plastic opening tool into the recess in the bottom center of the battery and lift upward.
    • Remove the battery from the phone.
    • When replacing the battery, align the copper ports on the top right of the battery with the corresponding ports in the battery cavity.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Samantha Fruge
260 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-4, Leahy Fall 2014 USF Tampa, Team 9-4, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S9G4
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 960
