Giriş
This guide will outline the step-by-step process of replacing the LCD screen of the JVC Adixxion GC-XA1BU.
Neye ihtiyacın var
Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
Use a Phillips #00 screwdriver to remove the two top screws (4mmx x 3mm). Once the screws are removed, carefully lift off the silver plate using Tweezers.
Follow these steps in reverse order with the new LCD screen in order to complete the replacement.
Bir başkası bu kılavuzu tamamladı.
