Ana içeriğe geç
JVC Adixxion GC-XA1BU LCD Screen Replacement
Neye ihtiyacın var
  1. JVC Adixxion GC-XA1BU LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Find the side of the camera with the black switch shown.
  2. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 2, 1 resimden 1.
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 3, 1 resimden 1.
    • Slide the battery cover back while pushing down on the black switch.
  4. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 4, 2 resimden 1. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 4, 2 resimden 2.
    • Open the battery compartment and push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the camera.
  6. JVC Adixxion GC-XA1BU LCD Screen Replacement, Battery Cover: adım 6, 1 resimden 1.
    • Remove the two Phillips screws (4mm x 3mm) using the Phillips #00 screwdriver.
  7. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Cover: adım 7, 2 resimden 1. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Cover: adım 7, 2 resimden 2.
    • Remove the 8 screws (5mm x 4mm) from the corners of both the front and back of the camera (4 screws on each side) using the T6 Torx screwdriver.
  8. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 8, 1 resimden 1.
    • Carefully open the camera as shown and gently peel off the black cover tape.
  9. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 9, 3 resimden 1. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 9, 3 resimden 2. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 9, 3 resimden 3.
    • Carefully lift up and remove the cable ribbon clip using the tweezers.
  10. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 10, 2 resimden 1. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 10, 2 resimden 2.
    • Carefully grasp and remove the ribbon cable using the tweezers.
  11. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 11, 1 resimden 1.
    • Turn the camera as shown and carefully remove the glue from the connector.
  12. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 12, 2 resimden 1. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 12, 2 resimden 2.
    • Carefully pull the white clip out of the casing using the tweezers.
  13. JVC Adixxion GC-XA1BU LCD Screen Replacement, Zoom (+/-) Buttons: adım 13, 2 resimden 1. JVC Adixxion GC-XA1BU LCD Screen Replacement, Zoom (+/-) Buttons: adım 13, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two top screws (4mmx x 3mm). Once the screws are removed, carefully lift off the silver plate using Tweezers.
  14. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 14, 1 resimden 1.
    • Once you have lifted and removed the silver plate, use a Phillips #00 screwdriver to remove the two bottom screws (4mm x 3mm).
  15. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 15, 2 resimden 1. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 15, 2 resimden 2.
    • Using Tweezers, gently pull the red, black, and white threaded wire to disconnect it, then remove the attached panel as shown.
  16. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Screen: adım 16, 2 resimden 1. JVC Adixxion GC-XA1BU LCD Screen Replacement, LCD Screen: adım 16, 2 resimden 2.
    • Carefully lift up and remove the LCD screen using the tweezers.
  17. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 17, 2 resimden 1. JVC Adixxion GC-XA1BU LCD Screen Replacement: adım 17, 2 resimden 2.
    • The screen as shown if removed properly.
Sonuç
Follow these steps in reverse order with the new LCD screen in order to complete the replacement.
Bir başkası bu kılavuzu tamamladı.
Christina Michelle Johnson
1.047 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Tanski Winter 2015 USF Tampa, Team 1-2, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G2
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 785
