Ana içeriğe geç
JVC Adixxion GC-XA1BU Lens (External) Replacement
Neye ihtiyacın var
  1. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery: adım 1, 1 resimden 1.
    • Find the side of the camera that looks like this.
  2. JVC Adixxion GC-XA1BU Lens (External) Replacement: adım 2, 1 resimden 1.
    • Push down on the black switch.
  3. JVC Adixxion GC-XA1BU Lens (External) Replacement: adım 3, 1 resimden 1.
    • While still pushing down on the black switch, slide back the battery cover (see photo for direction).
  4. JVC Adixxion GC-XA1BU Lens (External) Replacement: adım 4, 2 resimden 1. JVC Adixxion GC-XA1BU Lens (External) Replacement: adım 4, 2 resimden 2.
    • Push the cover up to open the battery compartment, and then push the blue battery release switch.
  5. JVC Adixxion GC-XA1BU Lens (External) Replacement: adım 5, 1 resimden 1.
    • You can now take the battery out of the camera.
  6. JVC Adixxion GC-XA1BU Lens (External) Replacement, Battery Cover: adım 6, 1 resimden 1.
    • After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
  7. JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): adım 7, 2 resimden 1. JVC Adixxion GC-XA1BU Lens (External) Replacement, Lens (External): adım 7, 2 resimden 2.
    • Using a 1x1xH1.5 torx screwdriver, remove the eight screws (5mm headsize / 4mm length) from the corners of both sides of the camera (4 screws on each side).
  8. JVC Adixxion GC-XA1BU Lens (External) Replacement: adım 8, 2 resimden 1. JVC Adixxion GC-XA1BU Lens (External) Replacement: adım 8, 2 resimden 2.
    • Twist the metal ring on the lens to the right and then pull it off.
  9. JVC Adixxion GC-XA1BU Lens (External) Replacement: adım 9, 2 resimden 1. JVC Adixxion GC-XA1BU Lens (External) Replacement: adım 9, 2 resimden 2.
    • Use the plastic opening tool to gently pry the lens off of the camera.
Sonuç
Christina Michelle Johnson
1.047 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Tanski Winter 2015 USF Tampa, Team 1-2, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G2
4 Üyeler
Bir Yorum
Where can the lens be purchased at?
Isaac Aguilar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 609
