Giriş
To complete this guide, you will need to purchase a new external lens and make sure that you have the tools listed. It is always good practice to make sure that the device is completely powered off and remove the battery before attempting any repairs.
  1. Find the side of the camera that looks like this.
    • Find the side of the camera that looks like this.
  2. Push down on the black switch.
    • Push down on the black switch.
  3. While still pushing down on the black switch, slide back the battery cover (see photo for direction).
    • While still pushing down on the black switch, slide back the battery cover (see photo for direction).
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Push the cover up to open the battery compartment, and then push the blue battery release switch. Push the cover up to open the battery compartment, and then push the blue battery release switch.
    • Push the cover up to open the battery compartment, and then push the blue battery release switch.
  6. You can now take the battery out of the camera.
    • You can now take the battery out of the camera.
  7. After removing the battery, take out  the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
    • After removing the battery, take out the two Phillips screws (4mm headsize x 3mm length) screws. You can now remove the battery cover.
  8. Using a 1x1xH1.5 torx screwdriver, remove the eight screws (5mm headsize / 4mm length) from the corners of both sides of the camera (4 screws on each side). Using a 1x1xH1.5 torx screwdriver, remove the eight screws (5mm headsize / 4mm length) from the corners of both sides of the camera (4 screws on each side).
    • Using a 1x1xH1.5 torx screwdriver, remove the eight screws (5mm headsize / 4mm length) from the corners of both sides of the camera (4 screws on each side).
  9. Twist the metal ring on the lens to the right and then pull it off. Twist the metal ring on the lens to the right and then pull it off.
    • Twist the metal ring on the lens to the right and then pull it off.
  10. Use the plastic opening tool to gently pry the lens off of the camera. Use the plastic opening tool to gently pry the lens off of the camera.
    • Use the plastic opening tool to gently pry the lens off of the camera.
Sonuç
Christina Michelle Johnson
1.023 İtibar
8 adet Kılavuz yazıldı
Takım
USF Tampa, Team 1-2, Tanski Winter 2015 USF Tampa, Team 1-2, Tanski Winter 2015 üyesi
USFT-TANSKI-W15S1G2
4 Üyeler
Bir Yorum
Where can the lens be purchased at?
Isaac Aguilar - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 2
Her zaman: 399
