Ana içeriğe geç
JVC GR-D72U Lateral Function Port Panel Replacement
Neye ihtiyacın var
  1. JVC GR-D72U Lateral Function Port Panel Replacement, Battery: adım 1, 2 resimden 1. JVC GR-D72U Lateral Function Port Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Locate button on bottom of camera.
    • Slide button to the right.
  2. JVC GR-D72U Lateral Function Port Panel Replacement: adım 2, 1 resimden 1.
    • Pull the battery towards the bottom of the camcorder while lifting battery .
  3. JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: adım 3, 3 resimden 1. JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: adım 3, 3 resimden 2. JVC GR-D72U Lateral Function Port Panel Replacement, Lateral Function Port Panel: adım 3, 3 resimden 3.
    • Remove silver plate that says “Auto Light” on the top of the camera using a metal spudger.
    • Remove the 3.1 mm screw.
    • Remove the three 5.3 mm screws from the back of the camera.
  4. JVC GR-D72U Lateral Function Port Panel Replacement: adım 4, 1 resimden 1.
    • From the bottom of the camera remove the following four screws:
    • 5.3 mm
    • 3.1 mm
    • 5.1 mm
    • 3.5 mm
  5. JVC GR-D72U Lateral Function Port Panel Replacement: adım 5, 1 resimden 1.
    • Use the small plastic opening tool to remove the blue side cover piece.
  6. JVC GR-D72U Lateral Function Port Panel Replacement: adım 6, 1 resimden 1.
    • Remove the 3.1 mm screw on top of the camera, closest to the LCD monitor.
    • Remove the 5.4 mm screw next to the snapshot button.
  7. JVC GR-D72U Lateral Function Port Panel Replacement: adım 7, 1 resimden 1.
    • Remove the 3.1 mm screw next to the USB and DV inputs.
  8. JVC GR-D72U Lateral Function Port Panel Replacement: adım 8, 1 resimden 1.
    • Gently pull apart both halves of the camera to reveal the inner components.
  9. JVC GR-D72U Lateral Function Port Panel Replacement: adım 9, 3 resimden 1. JVC GR-D72U Lateral Function Port Panel Replacement: adım 9, 3 resimden 2. JVC GR-D72U Lateral Function Port Panel Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Flip the cable locks to the up-position and pull both cables connecting the lateral function port panel to the rest of the camera.
    • Insert the cables from the new port panel into their inputs and flip the locks to the down position.
    • It is easier to use tweezers when inserting the cable but not required.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joshua Hatcherian
194 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G2, Nance Fall 2017 USF Tampa, Team S2-G2, Nance Fall 2017 üyesi
USFT-NANCE-F17S2G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 446
