Ana içeriğe geç
JVC GR-D93U LCD Screen Replacement
Neye ihtiyacın var
  1. JVC GR-D93U LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. JVC GR-D93U LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. JVC GR-D93U LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Unscrew 3 mm Phillips #0 screws around the LCD Screen. You will have to turn the screen to get the screws on the bottom of the screen.
  2. JVC GR-D93U LCD Screen Replacement: adım 2, 1 resimden 1.
    • Pry apart the plastic casing around the screen using a flat spudger tool
  3. JVC GR-D93U LCD Screen Replacement: adım 3, 2 resimden 1. JVC GR-D93U LCD Screen Replacement: adım 3, 2 resimden 2.
    • Carefully remove the wires connected to the screen from the black box. Now you will be able to separate the screen from the camera.
  4. JVC GR-D93U LCD Screen Replacement: adım 4, 2 resimden 1. JVC GR-D93U LCD Screen Replacement: adım 4, 2 resimden 2.
    • Unscrew the 5 mm Phillips #0 screw that is connecting the screen to the plastic casing.
  5. JVC GR-D93U LCD Screen Replacement: adım 5, 3 resimden 1. JVC GR-D93U LCD Screen Replacement: adım 5, 3 resimden 2. JVC GR-D93U LCD Screen Replacement: adım 5, 3 resimden 3.
    • You can now take out the screen to be replaced. Carefully remove cables from the data board.
Sonuç
Lindsay
267 İtibar
2 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 1-5, May Spring 2015 Colorado Springs, Team 1-5, May Spring 2015 üyesi
UCCS-MAY-S15S1G5
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 780
