Giriş
Removal of the driver side panel of the device will allow access to other internal components.
Neye ihtiyacın var
Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
Remove the top panel.
After removing all screws and top panel, lift up disc drive from steel enclosure.
Remove the six pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
