Ana içeriğe geç
JVC KW-V820BT Front Panel Assembly Replacement
Neye ihtiyacın var
  1. JVC KW-V820BT Front Panel Assembly Replacement, Front Panel Assembly: adım 1, 3 resimden 1. JVC KW-V820BT Front Panel Assembly Replacement, Front Panel Assembly: adım 1, 3 resimden 2. JVC KW-V820BT Front Panel Assembly Replacement, Front Panel Assembly: adım 1, 3 resimden 3.
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. JVC KW-V820BT Front Panel Assembly Replacement: adım 2, 2 resimden 1. JVC KW-V820BT Front Panel Assembly Replacement: adım 2, 2 resimden 2.
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. JVC KW-V820BT Front Panel Assembly Replacement: adım 3, 3 resimden 1. JVC KW-V820BT Front Panel Assembly Replacement: adım 3, 3 resimden 2. JVC KW-V820BT Front Panel Assembly Replacement: adım 3, 3 resimden 3.
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  4. JVC KW-V820BT Front Panel Assembly Replacement: adım 4, 1 resimden 1.
    • Gently remove the front panel from the steel enclosure.
  5. JVC KW-V820BT Front Panel Assembly Replacement: adım 5, 3 resimden 1. JVC KW-V820BT Front Panel Assembly Replacement: adım 5, 3 resimden 2. JVC KW-V820BT Front Panel Assembly Replacement: adım 5, 3 resimden 3.
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 577
