Ana içeriğe geç
JVC KW-V820BT Passenger Side Panel Removal and Replacement
Neye ihtiyacın var
  1. JVC KW-V820BT Passenger Side Panel Removal and Replacement, Front Panel Assembly: adım 1, 3 resimden 1. JVC KW-V820BT Passenger Side Panel Removal and Replacement, Front Panel Assembly: adım 1, 3 resimden 2. JVC KW-V820BT Passenger Side Panel Removal and Replacement, Front Panel Assembly: adım 1, 3 resimden 3.
    • Remove the four 1/8-inch black machine screws using a Phillips #00 screwdriver.
  2. JVC KW-V820BT Passenger Side Panel Removal and Replacement: adım 2, 2 resimden 1. JVC KW-V820BT Passenger Side Panel Removal and Replacement: adım 2, 2 resimden 2.
    • Remove three steel-finish, pan-head, 1/64 x 3/16" machine screws identified in the photograph, using the Phillips #0 screwdriver.
  3. JVC KW-V820BT Passenger Side Panel Removal and Replacement: adım 3, 3 resimden 1. JVC KW-V820BT Passenger Side Panel Removal and Replacement: adım 3, 3 resimden 2. JVC KW-V820BT Passenger Side Panel Removal and Replacement: adım 3, 3 resimden 3.
    • Using your fingers and/or a metal spudger, gently release the plastic locking tabs of the front panel assembly from the steel enclosure while prying the front panel assembly away from the steel enclosure with your fingers.
  4. JVC KW-V820BT Passenger Side Panel Removal and Replacement: adım 4, 1 resimden 1.
    • Gently remove the front panel from the steel enclosure.
  5. JVC KW-V820BT Passenger Side Panel Removal and Replacement: adım 5, 3 resimden 1. JVC KW-V820BT Passenger Side Panel Removal and Replacement: adım 5, 3 resimden 2. JVC KW-V820BT Passenger Side Panel Removal and Replacement: adım 5, 3 resimden 3.
    • Gently separate the ribbon cable from from ZIF connector on the circuit board using a metal smudger.
    • Be careful not to scratch or damage components or features of the circuit board with the metal spudger
  6. JVC KW-V820BT Passenger Side Panel Removal and Replacement, Top Panel Removal: adım 6, 3 resimden 1. JVC KW-V820BT Passenger Side Panel Removal and Replacement, Top Panel Removal: adım 6, 3 resimden 2. JVC KW-V820BT Passenger Side Panel Removal and Replacement, Top Panel Removal: adım 6, 3 resimden 3.
    • Remove seven 1/64 x 3/16" screws from the top panel using the Phillips #0 screwdriver.
    • Remove the top panel.
  7. JVC KW-V820BT Passenger Side Panel Removal and Replacement, Passenger Side Panel Removal and: adım 7, 3 resimden 1. JVC KW-V820BT Passenger Side Panel Removal and Replacement, Passenger Side Panel Removal and: adım 7, 3 resimden 2. JVC KW-V820BT Passenger Side Panel Removal and Replacement, Passenger Side Panel Removal and: adım 7, 3 resimden 3.
    • Remove the five pan-head, 1/64 x 3/16" machine screws using a Phillips #0 screwdriver.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 156
