Ana içeriğe geç
JYX-S55 Speaker Replacement
Neye ihtiyacın var
  1. JYX-S55 Speaker Replacement, Speaker: adım 1, 2 resimden 1. JYX-S55 Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Remove the four screws from the top panel of the device using a 2.5 hex screwdriver.
    • Remove the top panel.
  2. JYX-S55 Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the four screws that keep the light strip in place using a JIS #1 screwdriver.
  3. JYX-S55 Speaker Replacement: adım 3, 2 resimden 1. JYX-S55 Speaker Replacement: adım 3, 2 resimden 2.
    • Lift out the plastic ring which contains the lights.
    • The lights will be connected with wires. These do not need to be cut or ripped out; simply place the plastic ring off to the side or somewhere out of the way.
  4. JYX-S55 Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the four screws at the corners of the woofer/speaker using a JIS #1 screwdriver.
  5. JYX-S55 Speaker Replacement: adım 5, 1 resimden 1.
    • Pull out the speaker’s woofer.
  6. JYX-S55 Speaker Replacement: adım 6, 2 resimden 1. JYX-S55 Speaker Replacement: adım 6, 2 resimden 2.
    • Use a pair of wire cutters to separate the speaker from the rest of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexandra Wehrhahn
151 İtibar
1 Kılavuz yazıldı
Ekip
Marist, Team 1-5, Chaterdon Spring 2023 Marist, Team 1-5, Chaterdon Spring 2023 üyesi
MARS-CHATERDON-S23S1G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 445
