Ana içeriğe geç
Jabra CRUISER2 Motherboard Replacement
Neye ihtiyacın var
  1. Jabra CRUISER2 Motherboard Replacement, Front Plate: adım 1, 1 resimden 1.
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • iOpener Instructions
  2. Jabra CRUISER2 Motherboard Replacement: adım 2, 1 resimden 1.
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Motherboard Replacement: adım 3, 1 resimden 1.
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Jabra CRUISER2 Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  5. Jabra CRUISER2 Motherboard Replacement: adım 5, 1 resimden 1.
    • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
    • The names of the screwdriver heads are listed on the sides of each head.
  6. Jabra CRUISER2 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the motherboard from the device by lifting it up from the back plate.
Sonuç
Spartacus
636 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-13, Williams Fall 2014 Baylor, Team 8-13, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G13
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 762
