Ana içeriğe geç
Jabra Elite 85h Bluetooth Module Replacement
Neye ihtiyacın var
  1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: adım 1, 3 resimden 1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: adım 1, 3 resimden 2. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: adım 1, 3 resimden 3.
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
    FixBot'a Sor
    Yorum Ekle
  2. Jabra Elite 85h Bluetooth Module Replacement: adım 2, 3 resimden 1. Jabra Elite 85h Bluetooth Module Replacement: adım 2, 3 resimden 2. Jabra Elite 85h Bluetooth Module Replacement: adım 2, 3 resimden 3.
    • The foam inserts and backing tape are very delicate, take your time when removing them and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
    FixBot'a Sor
    Yorum Ekle
  3. Jabra Elite 85h Bluetooth Module Replacement: adım 3, 3 resimden 1. Jabra Elite 85h Bluetooth Module Replacement: adım 3, 3 resimden 2. Jabra Elite 85h Bluetooth Module Replacement: adım 3, 3 resimden 3.
    • Repeat previous steps on other side.
    FixBot'a Sor
    Yorum Ekle
  4. Jabra Elite 85h Bluetooth Module Replacement: adım 4, 1 resimden 1.
    • Unscrew and remove the four T6 screws holding the speaker in place.
    FixBot'a Sor
    Yorum Ekle
  5. Jabra Elite 85h Bluetooth Module Replacement: adım 5, 1 resimden 1.
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
    FixBot'a Sor
    Yorum Ekle
  6. Jabra Elite 85h Bluetooth Module Replacement: adım 6, 2 resimden 1. Jabra Elite 85h Bluetooth Module Replacement: adım 6, 2 resimden 2.
    • Remove the two screws holding the upper and lower circuit boards in place.
    FixBot'a Sor
    Yorum Ekle
  7. Jabra Elite 85h Bluetooth Module Replacement: adım 7, 2 resimden 1. Jabra Elite 85h Bluetooth Module Replacement: adım 7, 2 resimden 2.
    • Remove the two attached circuit boards from the headphone housing.
    • De-solder Bluetooth Module from control board to replace.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Callaghan
965 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Petersen Spring 2023 UMass Dartmouth, Team 3-4, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S3G4
4 Üyeler
18 adet Kılavuz yazıldı
2Kılavuz Yorumları
But where could one get this Bluetooth Module? Is it only available for Jabra workers?
sarita sulkakoski - Yanıt Paylaş
Anyone can tell how I can get parts for this thing - need main module
Janusz Pokorski (Smartthing) - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 2,565
