Ana içeriğe geç
Jabra Elite 85h Bluetooth Module Replacement
Neye ihtiyacın var
  1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: adım 1, 3 resimden 1. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: adım 1, 3 resimden 2. Jabra Elite 85h Bluetooth Module Replacement, Bluetooth Module: adım 1, 3 resimden 3.
    • Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
    • If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
  2. Jabra Elite 85h Bluetooth Module Replacement: adım 2, 3 resimden 1. Jabra Elite 85h Bluetooth Module Replacement: adım 2, 3 resimden 2. Jabra Elite 85h Bluetooth Module Replacement: adım 2, 3 resimden 3.
    • The foam inserts and backing tape are very delicate, take your time when removing them and be careful to not rip or tear the material.
    • Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
  3. Jabra Elite 85h Bluetooth Module Replacement: adım 3, 3 resimden 1. Jabra Elite 85h Bluetooth Module Replacement: adım 3, 3 resimden 2. Jabra Elite 85h Bluetooth Module Replacement: adım 3, 3 resimden 3.
    • Repeat previous steps on other side.
  4. Jabra Elite 85h Bluetooth Module Replacement: adım 4, 1 resimden 1.
    • Unscrew and remove the four T6 screws holding the speaker in place.
  5. Jabra Elite 85h Bluetooth Module Replacement: adım 5, 1 resimden 1.
    • Tilt the headphones over so that the speaker tilts out of the plastic holder.
    • Repeat for both sides.
  6. Jabra Elite 85h Bluetooth Module Replacement: adım 6, 2 resimden 1. Jabra Elite 85h Bluetooth Module Replacement: adım 6, 2 resimden 2.
    • Remove the two screws holding the upper and lower circuit boards in place.
  7. Jabra Elite 85h Bluetooth Module Replacement: adım 7, 2 resimden 1. Jabra Elite 85h Bluetooth Module Replacement: adım 7, 2 resimden 2.
    • Remove the two attached circuit boards from the headphone housing.
    • De-solder Bluetooth Module from control board to replace.
Sonuç
Ryan Callaghan
962 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Petersen Spring 2023 UMass Dartmouth, Team 3-4, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S3G4
4 Üyeler
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
But where could one get this Bluetooth Module? Is it only available for Jabra workers?
sarita sulkakoski - Yanıt
Anyone can tell how I can get parts for this thing - need main module
Janusz Pokorski (Smartthing) - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 2,297
