Neye ihtiyacın var
Remove each ear cushion by hooking your fingers along the inside of the ear cushion and pulling up and away from the ear cup.
If the cushion does not fully release, move your hand to the opposite side and pull up inn the same manner.
Using the small plastic spudger to assist, begin lifting up and removing the foam inserts with attached backing tape.
Remove the four screws attaching the circuit boards to the headphone enclosure.
If the microphone on your Jabra Elite 85h is not working, replacement could be an appropriate solution.
Bir başkası bu kılavuzu tamamladı.
